Blackmagic94
- 9
- 18
- Oro Valley/AZ
Will they clear stock or I need a lift?
Why do you say they won't fit?They won't fit the wheels I have. I need to keep the ctis
Gearing wise it would add top end speed, BUT... the tires themselves are speed limited to 55mph...probably due to the soft sidewalls offroad tires have. There's been some debate on here that the factory speed limit of the tires to 55 was set based on the tire being fully loaded which is near impossible on a 5 ton since each tire can hold 14,540 lbs (x 6 tires= 87,540 lbs!!!)...Logic says that at a load of only 25% and a lower air pressure than the max of 120psi, the tire would be safe at higher road speeds...that is up to each driver to decide...there is that one 5 ton that was clocked doing a steady 80+?!?!?!What will the 1600s do to cruise speed?
