I verified that the truck is not charging... Voltmeter across the batteries shows 24 volts and doesn't change when running, not running..
Also shows "yellow" on the guage... i'm very sure its not charging
TESTING I HAVE DONE
I replaced the regulator about a year ago with a new military solid state one, I had the generator tested when i replaced the regulator, (year ago) they said it was fine... (pegged the needle they said... not sure what that means)
I have the "test" adapter.. but i'm not sure about the results of my tests...
What should i be testing and how?
The manual stated. . .
1) Remove the cable connecting the gen to the regulator
2) Insert the adapter to the gen
3) Connect a wire (shunt) from the ARM to the FIELD
4) Measure voltage from ARM to the gen ground (adjustment bolt)
I get nothing though...
"Replace and See what happens . . " advice is great when you can charge a customer for the parts, but not when its my checkbook.. before i spend $120+ on a regulator and twice that on a generator, id like to actually know whats broken..
thanks
Chris
TESTING I HAVE DONE
thanks
Chris
