From a portability standpoint, a MEP-016D will fit between the rear seat and back doors on a Suburban...MEP-016D is my favorite. Yanmar powered and has a pull rope for manual starting. I would consider it two man portable although I can muscle mine around all by myself. Mine is my go-to unit when I need portable power somewhere remote. It has very good efficiency.
A Honda EU2000 is hard to beat for portability, though.
Amolaver, the modern inverter type generators are very good provided you understand their limitations. We had some Honda inverter generators in my department. In exchange for the lower noise, you get a generator that cannot be run for more than three hours when operated at or above 50 percent output. The manual specifies a prolonged shut down and maintenance check every three hours, hence our carrying multiple generators. Military generators are far more robust with far longer run times between required shut downs and checks.
Another thing to consider is whether you will use this type of generator with certain electronics. Most of them, especially the Honda's, have reasonably clean sine wave output, EXCEPT for certain sections of the radio frequency spectrum. The ARRL did an actual test and published their results a few months back on a slew of these inverter generators. Some of them wipe out whole sections of RF space. These generators may not be the best choice if you intend to use them with radio equipment.
As with anything, there is no one piece of equipment that does everything well. The MEP's give solid, clean power that is good enough for comm centers, but the price is noise. The civilian inverter generators give solid, quiet power for short durations at the expense of RF hash.
John
interesting - i was not aware of the RF output of the inverters. i wonder how many field days got ruined because of that!
i've seen many of the inverters run non-stop for 3 or 4 days to power RVs/trailers/campers at the track. i just had a look at the yamaha EF2400 owners manual and it has no 3 hour shutdown requirement. they have an initial 20hour oil change interval, and then 100hour intervals. owners manual i looked at is here http://www.electricgeneratorsdirect.com/manuals/EF2400is.pdf
ahm
