5KW TQG MEP-802A TM's and info
LuckeyD
388
Vilseck, Germany
This is what is available from the military concerning this gen. Issues: Battery charging gen was changed in 2005, old ones still out there, both work.. Alternator hook up incorrect by soldiers, batteries changed to AGM batteries in 2010, injector pump and rack incorrectly installed causing various issues, not serviced, plugged radiators inside and out, incorrect S8 settings and load terminal connections causing Volt reg issues, fault panel issues, S1 and S6 sand intrusion and changed because of, K1 issues. Body panel issues. Once in order, this gen will serve you well and makes a great house power backup for some of your house set to 120/240VAC
