5ton 24r21 rims
BIGNICK
SEWELL NJ
I am looking for 24r21 rims to fit on my 5 ton. Found tires, now I have to find rims or have them made
tcody
Illinois
OTR wheel is the OEM supplier to PACCAR for 18x21 rims for use with the 24R21 tires. I know you can still buy them as they are used for the flotation tire option on their oilfield trucks and C500's. I am not sure what offset they are available in. I would guess they will set you back about 1200-1500 USD each but you could contact them directly or ask the local KW dealer. Home
tonka tester
N.E. Il
where does one find the 24r21 tires? i have only found a few... but theyre always worn down to nothing, or look too scary for road use :shock:
Victor
Pelham NH
I'll take 4 tires with rims (24R21) in any condition. Side wall MUST to be solid.
My friend owns Michelin retread facility. he can put any tread I want, but as I noted side wall must be in good shape.
Are these rims (21x18 ) one solid rim or 2 pieces?
tcody
Illinois
There were 2 lots at GL on 6/3 that had several - wonder if someone here got em. They were lots 7707/8701 and 8702. Good luck on the hunt
porkysplace
1,491
mid- michigan
Sorry, I'm new here. I did try the classified section but it was locked? That was last week so I suppose I'll try again.
Thanks for the tip!
You have to be a premium member to use the classifieds , there is a sticky at the top of the classifieds explaining this . Go to the resources section on the top tool bar and click on premium memebership It costs $15 a year.
jrod66
norcal
are you going to run tandem in the back? You can contact stazworks.com and they will build whatever wheel you would like, super tough but the lead time is a little long (at least he is honest about the time frame) but worth the wait for sure, they build wheels for Top Truck Challenge competitors, good luck with you build and keep us updated!:beer:
porkysplace
1,491
mid- michigan
This thread is 3 years old I doubt any updates are coming from the OP.
markmontana
Mesquite, NV/Layton, UT
I'm not a premium member- and I use classifieds all the time! (My premium membership was declined...)
73m819
320
gainesville, ga.
What do you mean DECLINED, WHO said that you could NOT become a PREMIUM MEMBER
4,795
I'm confused by this as well. If it was a payment issue, unfortunately that's between you and paypal. For those whom aren't up to using paypal, there is also an address to mail payments into.
