5Ton ALT. DILEMMA!!(PICS)
No.2Diesel
11
Huntington, NY
Hi,
Maybe you 5ton owners can share your input on this...Purchased a rebuilt alternator from CME Armature (took forever) to replace the existing one that doesn't charge due to always running on dead batteries from the previous owners.
The NSN (2920-00-909-2483) and the Mil Spec # (MIL-G-46795E(AT)) are the same for both the old and new unit. The problem lies with the shape of the front face of the units case. They are not the same and I can't swap the aluminum fan and pulley from the old unit to the new one.
The old alt. case has a stepped front face and the fan blades follow this contour. The new unit has a completely flat front face and the fan would contact the case if installed. Its not a matter of adding washers due to the fact that the shaft is not long enough to accomodate them. Otherwise the mounting ears and other things appear to be the same.
If someone out there in MV world has an aluminum fan and a matching pulley that goes with a flat faced 5ton alternator, contact me as I need one pronto. Thank you for your time.
Here are some pictures to better illustrate the problem.
1,807
The fan is internal on the replacement alternator. We figured this out at Aberdeen when we replaced the alternator on CGarbees ride. AM General can conrifm this too.
Westech
CPL
6,104
207
cow farts, Wisconsin
who replaced the alt on cgarbiees truck? We? I think I had to get my little lunch hooks in there lol But really Kenny is right the new style is a tad different but work just as good. I have the newer style on my deuce and 5 ton.
1,807
Westy is right. The pulley replacement was more of a group discussion. Westy mounted the fender. Sorry Rich.
1,127
Re: RE: 5Ton ALT. DILEMMA!!(PICS)
mangus580 said:
At least it wasnt OCD-boy who had the square out, making sure the lettering on my freeze plug was straight!
Hey!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1,807
Beggars can't be chooosy. I don't think anyone saw you up on that fender putting in the freeze plug.
acetomatoco
RE: Re: RE: 5Ton ALT. DILEMMA!!(PICS)
Your answer is to just mount the pulley on your CME Arma rebuild and away you go... save all the old stuff as the cores are worth some money....
No.2Diesel
11
Huntington, NY
If there ever was one word (not sure if its an actual word) to describe my thoughts right now... DUH!!!
I was looking at the internal fan many times point blank range. Block head syndrom again. Thank you ACE, Recovery and others for your help.
mangus580
282
Western NY
Was too busy falling off the back of the truck!
halftrack
10
New Orleans, LA
You just reuse the pulley from the old alt. The newer one is just the more modern replacement, however, they been around awhile too. Change out about ten of them so for.
1,807
I know I'm drifting off topic a bit but that first step off the back of a deuce is hell in the middle of the night when you gotta take a leak. Just thought I'd share that. Back to your regularly scheduled alternator discussion.
