6.2 banks turbo oil dump question???
hokie8358
backwoods ,virginia
i bought this turbo from ebay bout month ago and it seems the part that delivers the oil from turbo bearings back to engine is missing. people at banks.com are useless!! maybe you all can give me sum insight and maybe a part number. does it flow to the mechanical fuel pump plate or back into the oil pan? i was going to install an elec. fuel pump. and buy the way it is an orig. 6.2 sidewinder banks turbo. kit is totally complete less this one minor detail>
jdeoliveira74
wilmington nc
I want one! can't help on part number though. but there is a couple of threads in here on it I think I rememeber reading that is some oil cooler lines that they re direct but I be wrong!
superburban
SL,UT
Originally, there was a plate that sandwiched between the mechanical fuel pump and the block that had a fitting for returning the oil to the pan. Some folks just weld a fitting onto the oilpan. Easy enough.
bearboley
Circleville Ohio
Ive never seen a plate that sandwiched in between pump and motor, not saying there wasn't any such animal but how would the pump still work longer cam rod or something. I've just used a smallblock chevy fuel pump block off plate easy to find in the junk I mean chrome section or you local autoparts store . Drill a hole then weld a fitting in. Instant turbo drain. Of course you have to use a electric pump then but your where anyhow. Keep the boost below 10 and your headgaskets will thank you.
hokie8358
backwoods ,virginia
i ve got 2 kits altogether, the other one has what appears to be a homemade metal drain of sum sorts that goes down and fastens on to the oil pan, fabricated hole in pan of course. i did not know if this was a gale banks factory type set up.
i do have all the working parts from a 6.5 diesel turbo set up(94 model chevy) i see what your referring to crappy. mine looks similiar to your pics. thanks. just tryin to take the most effective road to reliability!
wkbrdngsnw
Aurora,Co
The option most people take is to replace the fuel pump with an electric one and take a block off plate and weld on a fitting. The banks version is the same thickness as the stock plate but has a tube that comes out turns 90 degrees and barely misses the pump. If your lucky you might be able to braze a 90 degree fitting into the stock plate close enough to still use the stock pump.
hokie8358
backwoods ,virginia
not bad idea but close quarters on the pump. i guess my mechanic thats doing it is sitting back weighing his options and to be the most effective sit up. thanks guys as always very helpful!!
wkbrdngsnw
Aurora,Co
why couldn't you tap into the oil cooler lines?
For the feed it would be ok but the return oil is really hot from being in the turbo and that is counter productive for cooling. Although the flow is still small it goes into the rest of the oiling system and any contaminate from the turbo could be a problem. Its always recommended to dump to the pan so it circulates though the filter before going to the bearings.
Dave87
Holland,Michigan
You wouldn't be able to tap the cooler lines for the return because they have pressure in them.
I went threw the fuel plate. Best way. I will post a picture when I get on my computer later. I called banks for the
oil return plate and they wanted 170 dollars for it. I've heard of guys going threw the pan but not being able to
get it to seal great. (Mustang guys)
panzerwillie
123
miami florida
I got one of those plates made a couple off the sample of the first kit i got i made a total of 3 kits , i can sale you
the original one i have it with kit i try to sale a few times but no body being intrested here is a picture of more less
what it looks like PM me if intrested:razz:
southdave
ripley, oh/TDY Lordstown,Oh
I welded a 3/4 bung on a delete plate, then used an 90 degree AN fitting with a hose barb on it. The drain on the turbo was 5/8 so I add more claps.. Word of caution.. be mindful of where you feed from.. I had AN 3 line feeding mine from above oil cooler line and spun my mains an a rod bearing...I have since resticted it down to 3/16 preasure is up and so is the pryo, it ran cooler before
