bigmech
- 0
- 16
- Potterville Mi 48813
My truck misses sometimes. Only under load. Just like a gas engine with a bad plug wire. It idles fine and sometimes runs great. But half the time it misses under load? Any ideas?
Your fuel filter backing plate is leaking air would be my guess.
You can get a new one on Ebay for about $75 shipped with filter.
Solved ALL SORTS of running issues with mine. Especially hard starting. Difficult to start a vehicle that's not getting solid fuel delivery.
Have someone rev the engine with the hood open with you standing next to where the fuel filter is. You might even here a slight 'whistle' type of noise. But I'd bet money you have an air leak, probably in the fuel filter backing plate.
Took me about an hour to replace mine. I also have an electric fuel pump inline to the fuel line before the fuel filter, so bleeding mine is as simple as opening the valve on the fuel filter, turn the truck on, wait for it to spurt fuel, close the valve, turn the truck off. Start the truck. That's it.
http://www.steelsoldiers.com/cucv/36435-my-cucv-spin-fuel-filter-mod-2.html#post700836
