6.2 on WVO in 110 temps
Gunfreak25
620
Yuma, AZ
I live in Yuma, AZ where it's about 110 in the summertime. Can the 6.2 run on a 50/50 diesel/WVO mix in this temperature okay?
Westech
CPL
6,104
207
cow farts, Wisconsin
Sure... it will just eat up the Injection pump and injectors. WMO in a 6.2 you really need to filter to 1-2 Microns and even at that the carbon in the fuel will eat stuff up.
Gunfreak25
620
Yuma, AZ
Thanks, and for winter temps which are usually 42 degrees at night and 55-60 during the day. Would the same mix do okay without heating or should the WVO be reduced to 25%? I am not ready to go full heated 100% WVO just yet, so I am looking at the different WVO/diesel ratios that will work for my area without needing dual tanks, heaters, etc. Whatever will cut the cost of fuel for now. :)
