AECS
- 6
- 18
- Munford, TN
I know that the timing chain on the 6.2 can stretch and retard timing. I am having problems when the M1009 starts cold, it smokes a lot, and idles very rough for about 5 seconds at the first start of the day. Once warm it is great. Once it cools down to about 100 on the gauge the fast idle and cold advance do not cycle on, it is worse, lots of smoke and rough for the first 10 or so seconds.
The IP was just rebuilt last month, the timing marks are lined up exactly. I don't know if I should look at the fast advance switch or the timing chain has stretched. Is there a way to check the slack in the chain without tearing it all down? I was thinking I might be able to see it through the oil fill hole?
