erasedhammer
- 58
- 28
- Maryland
So old diesels are known for not having those modern emission control devices installed on them, so I was wondering if anyone had hooked up a stock 6.2l to a emissions test and see what the results are. Of course the new diesels would have pretty high particulate emissions if the fuel wasn't being burnt all the way, but I don't imagine that the particulates would be anywhere near as much since the 6.2l are so under powered. And since the 6.2s are under powered the heat required to produce a significant amount of NOx would be lowered since the engine wouldn't run as hot as the newer 300+ HP diesels?
Also I was looking on GMs website and they say that the 6.2l that was given to the army in the humvee had a stock HP of 165 at 3600 RPM and 330 ft/lbs of torque at 2100 rpm. But I always thought that the stock 6.2s were 150 and 250 ft/lbs. Thoughts?
"The 6.2L diesel was ordered with regular production option codes (RPO) LH6 (C series) and LL4 (J series). Many vehicles employed by the United States' Army were powered by the 6.2L diesel, from pickups to HUMVEES. The Army version had a higher output rating of 165 horsepower and 330 lb-ft of torque, quite an increase over the production engines."
UPDATE:
Found this on wikipedia (Detroit Diesel V8 6.2l), almost every data point I find is different... its interesting that GMs website says 165 hp then wikipedia says 185 hp.
Specifications
Peak Horsepower: | Introduced at 130 hp @ 3,600 rpm, maximum offered during production was 143 hp @ 3,600 rpm. The United States Army's version was rated at 165 hp @ 3,600 rpm. |
Peak Torque: | Introduced at 240 lb-ft A 2,000 rpm, the maximum offered rating during production was 257 lb-ft @ 2,000 rpm. The United States Army's version was rated at 330 lb-ft @ 2,100 rpm. |
UPDATE:
Specifications
- Compression: 21.5:1
- Injection: Indirect
- Horsepower / Torque (at start): 130 hp (97 kW) @ 3,600 rpm / 240 lb·ft (325 N·m) @ 2,000 rpm
- Horsepower / Torque (at final): 160 hp (119 kW) @ 3,600 rpm / 285 lb·ft (386 N·m) @ 2,000 rpm
- Horsepower / Torque (US Army HMMWV model): 185 hp (138 kW) @ 3,600 rpm / 330 lb·ft (447 N·m) @ 2,100 rpm
- Max RPMs: 3,600 rpm
- Idle RPMs: 550 ± 25
