Brogman
- 3
- 18
- Noblesville, Indiana
6.5NA hummer engine in M1009
I just bought a NA 6.5 Hummer engine, I haven't received it yet. I have some questions too.
My M1009 is 12v with a passenger side Alt. I know the water pump has to be changed if the 6.5 has a serpentine belt so I can use my V belt set up.
I read the temp/oil/ sensors are 24 volt as well as the IP electrics so need 12v stuff? Where can I get these? Glow plugs?
Will my new 12v starter and flex plate work from my 6.2 on the 6.5?
I read that the 6.2NA intake manifold has better air flow than the 6.5NA so will the 6.2NA intake work on the 6.5?
Will the 6.2 vacuum pump and vacuum valve on the IP for the transmission shift fit the 6.5?
Will the Hummer exhaust manifold fit in my M1009? I plan to have a new exhaust installed to the new manifolds if they fit.
I am sure I will have a few more questions. Thanks for the help.
