6.5 TD Throttle Position Sensor voltage ?
bobwire
Satellite Beach Florida
Does anyone know what the proper voltage values are supposed to be on the TPS of a 6.5 GEP TD?
My shift controller is giving me a TPS error code resulting in irregular shifting. (4L80E)
Im getting 0.4 volts at idle and 2.39 volts WOT.
Seems kinda low, but I never tested it when it was working properly so I really dont know for sure.
thanks
Keith_J
1,316
Schertz TX
The sensor gets a 5 volt signal from the TCM and sends a 0.5 to 5 volt signal to the TCM depending on throttle position. It should be at least 4.5 volts at wide open.
