6.5 Tick When Warm 1151A1 2007
SDgovvehicles
South Dakota
Hey all, I just picked up a couple of 1151A1's with the turbo 6.5 and have one that has a loud ticking noise that changes with rpm. It seems to come from the passenger rear of the motor. Oil pressure is around 17psi idle when warm and 45 when cruising warm. When it's cold it doesn't do it at all and progressively gets louder as it warms up. It also goes away if you run it wide open down the road for a couple miles. After about a minute of idling or even being revved but sitting, it comes right back. I have cracked all injector lines multiple times, checked flex plate for cracks, removed serpentine belt, and have changed oil/filter with fresh Rotella 15w-40. I also tried some sea foam in the oil, but the tick never seems to get any worse or better except like i said after a full throttle run for a couple miles or when the motor is cold. I have been around multiple 6.5's before and its definitely not the standard diesel clanking that these give off. Any idea what this could be? Thanks!
Mogman
9,569
Papalote, TX
Welcome to the SS forums.
It sounds like a leaking lifter not able to stay pumped up, sometimes they will clear up on their own but if not you may need to replace it.
Mogman
9,569
Papalote, TX
If it is a lifter it should be clear what side of the engine the noise is coming from you can verify buy listening to the valve cover on that side.
I use (CAREFULLY) a large screw driver with the handle end to my ear.
How many miles have you driven or time have you spent with the engine running? getting the engine to full temp seems to help, it also takes some time for that additive to work its way to the lifter.+
Lifters have a "tinny" sound.
Best of luck on this!!
SDgovvehicles
South Dakota
If I pull off the valve covers to check the lifters out, is there an easy way to tell which lifter is giving issues and can I just replace the one while the head is still in place?
SDgovvehicles
South Dakota
I've ran it for a couple of hours and never gets better or worse unless I'm actually running it under a load on the highway. It doesn't matter if I rev it to 2500 rpm for 10 minutes, it is there instantly. It's definitely coming from the passenger side.
Mogman
9,569
Papalote, TX
Maybe someone else can chime in, I have not tried it myself but read it is "doable" but a REAL PITA.
So I would give it as much time as possible before going that route.
If it is really loud you should be able to tell which lifter it is with the valve cover off. (edit it will have play in it with the valve closed)
TOBASH
3,483
Brooklyn, NY
See if it clears with higher viscosity oil.
OR, wash out engine with tranny fluid mix vs commercial oil cleaner and then replace with Rotella 15-40.
87cr250r
1,988
Rodeo, Ca
I'm here to watch. Bought an eBay engine with a tick that comes and goes. I pulled all lifters and cleaned and disassembled. Tick is the same. Engine runs perfectly but there is a cracked head that makes some bubbles. The tick is exactly 1/2 crank speed. Use your cellphone's slow mo video feature to verify this. I wonder if mine is a cam bearing? I've checked everywhere else.
  • Like
Reactions: cwc
