6.5L Serpentine Belt Conversion
ICT_HMMWV
I have an '89 M998 w/ a 6.5L N/A engine/ 3sp tranny. The engine currently has dual v-belts. The simple question is can I convert the v-belts to serpentine? The more complicated question if possible how?
Coug
4,173
Olympia/WA
I believe at minimum you have to swap to a different water pump as it is reversed direction on the serpentine from the V-belt style.
Some of the other accessories may also be reverse spin.
So yes, it is possible, but does involve more than just swapping pulleys.
Maxjeep1
1,912
Las Vegas Nevada
Simpler question is why do you need to? I believe NASCAR still uses v-drive and It’s less likely to slip. I think if it came with serpentine belt great and if not cost doesn’t justify the gains. All you get is it’s easier to adjust belt? What are you looking for end result?
Mogman
8,656
Papalote, TX
While the cost and effort my not be worth the gain I have never heard anyone assert that a V belt was less likely to slip! mine squeal like a pig stuck under a rail fence every time the fan kicks in. also there is no "adjustment" on a serpentine belt
Maxjeep1
1,912
Las Vegas Nevada
That’s awesome! It’s classic it’s a quirk of your vehicle nothing wrong with a pig stuck in a fence squeeling I think that’s how I met my first wife . I can’t find my glasses this morning so I’m not really sure what in typing
