Ok, here's some solid data for you.How can I visually see the difference between a 6.2L, 6.5L, and 6.5L turbo engine? My m998 was marketed as a 6.5L turbo but has a 3 speed transmission still. I'd just like to confirm that they sold me the right truck.
I didn't know this at all. Got any pics of the difference? Googling now.GP has not sold any turbocharged HMMWVs yet. The certain id for 6.2 vs 6.5 is the oil pump drive clamp in the rear engine valley, drivers side is 6.2, passenger side 6.5.
Easiest way to check those bolts will be to sit in one of the front seats, remove the doghouse/"engine cover" from inside the cab, and look at the "valley" of the block. You'll see the oil pump/tach drive quite plainly from this perspective and it will be very easy to judge which way the bolt is facing and thus, what size engine you have. What's trickier is figuring out if you have a GM 6.5L or a GEP 6.5L. The difference doesn't really matter unless you're performance tuning the engine, in which case the GEP will have better alloys and construction than the GM to deal with the increased heat more effectively. For 99% of HMMWV owners, it's a moot point and you probably have the GEP, anyway.Thanks for the help guys! It's not a turbo. I'm still trying to figure out how to tell if it is a 6.5L or not. As a self taugh mechanic (aka, this is the first car I've ever worked on) im still trying to find the bolts described in the article, but I'll figure it out eventually.
