6.8 V10 in a deuce?
Halo615
15
Nashville Tennessee
I've done my research on the 5.9 6BT 12Valve (would love to put one in my deuce but the price of a decent one is crazy!) I've found an affordable 2018 6.8 V10 Gas engine with 6 speed automatic transmission. I cant find anything on one being put in a deuce, has anyone done this swap before and is it worth the effort?
HDN
4,923
Finger Lakes Region, NY
This is for your old gasser right? I'd say give it a shot. Up to you if you want to try and keep the transmission or try to mate it with the old 5-speed. I don't know anything about the 6-speed automatics that came with that motor or the load it can handle.
Budrow
13
Yakutat, Alaska
I have a v10 in my old Dodge dually, it’s a nice running motor with good power, but it guzzles gas like no other. Still might be cheaper than diesel these days though.
V8srfun
538
Altoona pa
Unless you want to loose your transfer case and all that it does I think you would be better off adapting to the deuce transmission. Things to consider how long is the engine, how wide is the engine, would the fuel economy become a problem, how much are you going to have invested in custom parts like mounts, cooling, fuel system, and so on. Another thing to consider is those engines are known to eat coils at $100 a pop things add up quick.
rustystud
2,760
Woodinville, Washington
That V10 engine develops more power then the Spicer 3053 can handle. You will tear up your transmission and clutch every time you "get on it" . If your determined to use this engine, then use the whole package. Engine, transmission and transfer case. You can always beef-up the transmission and transfer case to handle the torque.
davidb56
1,237
Bonners Ferry Idaho
It "may" also fit better with the transfer case attached to the transmission too. maybe a little firewall sheet metal work instead of the hood and nose panels too. Lots of tape measure work to do first.
fleetmech
384
Connecticut
That 6.8 can move an f550/ trailer combo that weighs more than a deuce faster than a deuce can go all with a 4:88 or maybe even 3:55 rear gear. It will have absolutely no problem hauling a loaded M35 around. Being a 2018 theres going to be a non trivial amount of wiring involved... make sure you get a complete donor truck with the necessary ECM, TCM, fuel pump driver ETC.
