6 inch lift
99dodge1500
Malta,Illnois
I have looked all over this site and on the internet and I still can't find if I need to do anything, to the drivetrain, if I where to get a 6 inch lift. I know I would have to get brake lines, but would I have to get some thing for the driveshafts or anything like that?
gt1009
st.charles,IL
You have to do some sort of steering mod, probably crossover would be best. Also you will need to fix your driveline angle somehow, mine is accomplished by a drop transfer case but my lift is only 4 inches.
gt1009
st.charles,IL
I don't really head into burlington ever but I don't think it's too far from my house. My house is pretty close to the boundary for burlington schools.
gt1009
st.charles,IL
Ha ya i'm the one in the lifted m1009 with the American flags in the window, not too many of those in St.Charles, just whatever Ranchopper sells off silver glen rd.
dunedigger
Hart, MI
A 6" lift on a chevy always requires driveshafts to be extended. It will require longer brake lines as you said and steering can be corrected by a longer pitman arm. With some kits that is included and in most cases if you buy a full spring kit the driveshaft angle will be corrected with shims already on the new springs. The front sway bar will need spacers put in to lower it down, those are availible to buy or you can fab some yourself. There are also some kits out there to lower the crossmember some to help with driveshaft angel if needed. A 4" lift doesn't always require driveshaft mods and the steering arm doesn't have to be changed but should. It will limit turning in one direction. The factory spacers on the top and bottom of the frame are relocated between the frame and crossmember to make up some driveshaft angle with a 4" lift also.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
A quick search for "lift kit" and a little time will get you all the answers. You can also go into the manufacturers web sites and they explain all necessary mods you will need. :roll:
maritimer
Yarmouth, NS
longer drive shafts, dropped pitman arm or cross over steering, possibley look at a SYE * slip yoke eliminator* kit, longer brake lines are a must. axle shims to correct drive line angle, drop your transfer case a bit.
off road design AKA ORD will put togetehr a lift of any hight for you and they specialize in early model chevys and knwo the trucks quite well. hope it helps
99dodge1500
Malta,Illnois
Yeah I think you are going to need that other server, hndrsonj I am sorry I did search and i did find that tread my eys must have played tricks on me I thought is said 4", and now reading all of this and at coloradok5 I am going with a 4"
1,177
We really should have modified forums, for each type of MV's.
