600 Gallon Fuel Tank
Earl_Beverly
Shepherd, Texas
I bought 4 of the aluminum 600 gallon fuel tanks from GSA/Forest service. They were used for water storage and have holes from corrosion and or electrolisys. Is there an easy fix? A cleaner and coating, or bladder for these tanks. Any help would be appreciated.
Earl_Beverly
Shepherd, Texas
Hi Phil and Wrekerman,
I really have need for the tanks. But, if I can't repair, I will keep you in mind on the lid.
I put in a blind bid with GSA and got these tanks. I never expected them to have the holes, rather that the valves, latches and such would need repair. I have used quite a bit of Brownells Acuglass epoxy with aluminum filings mixed in. That may be the answer. I have also considered a small wire feed welder.
Earl
stampy
22
Henderson. NC
Expoxy may expand differntly than the aluminum if there are large temperature swings. I would heliarc or braze with aluminum rod and a torch.
emr
24
landing , new jersey
I have one like new with the 24 volt pump and hose and nosel , yeesh cant spell that one,,, and black bucket that goes with a complete set for 1500.....A military hand pump goes with it too. ....fyi....
Bill W
42
Brooks,Ga
If they are just pinholes I would coat the tank with Steel Flex#9XS made by Fasco ( see link )
I've used this product on my bilge cleaning truck which had a 400gal steel tank which I later replaced with a mil aluminum 600gal tank( I coated the bottom half of both tanks ) It is extremely durable and will hold up to oil and gasoline
Fasco unlimited
