pinwormfood
- 0
- 0
- easton, pa
hey guys, i picked up a 6707 tunable whip base and whip and I wanted to know what wire will i need to connect it to my civy cb radio. it's a standard cobra classic model. also, when hooking up that base, do i need to ground it? and what other wires will i need to connect to the base? sorry, but I just can't seem to find the info doing searches.
secondly, an electrical question. I have the 2 bus bars behind my passenger seat wall. the top is 24 volt hot and I am told the bottom is a ground bus. is that correct? and if i run the top bar to the front battery instead of the standard 24volt connection point, that will give me 12 volt to run my cb, correct? and can I just hook up the cb ground to the lower bus bar? just checking. this stuff is all greek to me. thanks, pinworm
