6CTA 8.3 - Check your balancer pulley / vibration dampers
Jason O
Lebanon PA
Hello Everyone
I noticed my drive belt was not alligned and beginning to fray. The vibration damper/ harmonic balancer began to seperate at the rubber layer, and the outer section moved away from the engine a 1/4 inch. Replacing the balancer is an easy repair and does not require a puller to remove it from the crankshaft.
Cummins P/N 3925568
This may be worth a look next time your doing a P.M.
- Jason
jcappeljr
27
Delta, PA.
I lost one before driving it home, from picking it up from Ft.Meade. Not fun,had to call a wrecker..
