Hey Gimpy,
The additive is called EDTA. It is designed to remove the lead sulfate covering from the lead plates in the batteries. This sulfate deposit is what reduces the batteries ability to take and keep a charge. The battery needs to be in good shape for this to work. If it has and broken plates or shorts, the EDTA won't help. David Doyle sent me some EDTA that he found in TN. I'm sure there are other vendors out there. The place in TN is:
Hydro Systems Supply
421 Anderson Avenue
Brownsville, TN 38012
The EDTA comes with the instructions for the rejuvinating process. I have done it on one of my batteries so far, but it turned out to have a dead cell. I plan on doing the other 3 when I get some more time. An immense amount of sediment and crap came out of the one I did.
The basic process is drain the old electrolyte from the battery, rinse thoroughly with water, add 1 TBS of EDTA powder (it helps to mix it into warm distilled water) to each cell, put the caps on, allow to soak for about an hour ( turn the battery several times every 15 minutes), dump the cells, rinse very well with a garden hose, refill with battery acid and charge slowly overnight.
