7" LED headlight mods?
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
They should be the same.
Are your lights in the "lower" position, like in your avatar? Is there interference?
cattlerepairman
3,187
NORTH (Canada)
Direct drop-in. No modifications needed. Loosen three slotted screws and remove headlight ring, remove existing headlights after unplugging 3 plugs for # 16, 17, 18 wires, insert LED lights and replug, replace headlight ring. Done.
vincentbsll
Pensacola, Fl
Well I got the LED's to work. I had to use the old halogen bulb buckets with the new light and new ring. The led complete kit wouldn't work without some modification.
MWMULES
345
DESOTO, KANSAS
vincentbsll something tells me the standard mounting points on your friends duce had been changed or you did not have the drop in version, shown below that most of us are using. Three nuts, three wires and a ground plus adjusting and you are done.
Squirt-Truck
Master Chief
162
Marietta, Georgia
Headlights went in with no issues, but, the lower brush guard had to be clearanced by 1/2" to clear the extended flat face and alignment post.
This was on an M-39 series.
