  • Thread starter Deleted member 11142
  • Start date
D
Guest
gimpyrobb
dumpsterlandingfromorbit!
27,791
788
Cincy Ohio
Has anyone changed their air horn to one that has a little bit deeper sound to it? I don't like how high pitch the stock horn is. I did some searching but most of the threads were of people put on the huge train horns that will blow out your ear drums, and that's not what I'm looking for.
I have a set of Hadleys that will go on my truck when I get the motivation. The larger diaphram and longer horn tubes will make them lower. Have you tried adjusting your horns on the truck? There should be a screw on the back of the diaphram that you can turn in/out to raise/lower the tone.
asgtoolman
Florence SC
I agree with gimpyrobb, try adjusting the sound with the screw on the back. I actually took mine apart, cleaned them completely, sprayed some WD-40 on the diaphram, reassembled them and "played" with the adjustment until I got the sound I wanted.
Capt.Marion
15
Atlanta, GA
If you search for "horn" and "deuce horn" and the like, you'll find a couple of decent threads about upgrading from the M-series air horns.
Don't use the built in search feature, go to google.com and type the following:
'searchquery site:steelsoldiers.com' where 'searchquery' is what you're searching for. It works a lot better than the site's built-in search function.
Vintage iron
Falmouth Ma.
Thank you Capt. Marion for the constructive way of advise other members on searching Steel soldiers archives. Nothing worse that seeing the same guys saying the same thing about "use your search feature" I think I will give that a try! Cool
Stan Leschert
87
North Vancouver, BC, Canada
I put in a train horn, donated off an old CN engine,
run off of the Aux Air spigot in the cab.
The Pipe band demanded that I not blow it if they are marching in front of us
.... that would be most parades.
But when else do we take the old girl out?
GTO Tiger
Port Huron, Michigan
I also don't like the high pitched sound on my son's M51. It is ear piercing load though! Didn't know about the adjustment. Will have to look into that.
A 23000lb vehicle shouldn't sound like a little foreign car! :evil:
980
24
Dover, New Hampshire
Check out this thread I made about the horn I built : http://www.steelsoldiers.com/deuce-...66181-installed-grover-products-air-horn.html
The Grover air horns are very easy to find in salvage yards and on e-pay. I paid $20 for mine. You will find that the volume is about the same but the tone is much more fitting for a truck of it's size. I made mine as a seperate system from my stock horn but you could run a line right off of your electric horn valve.
Hope this helps, good luck!
-GM
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
I thought about one of those loud train horns. But I figured I would have some old person cut me off and I use it and gives them a heart attack and they go off the road. Or going through the woods and blow it at a moose and then we got a standoff.
dmetalmiki
2,036
London England
HA! noise?
well ..when I approach an intersection..(or just when I feel like it) I "TOOT" these...(CARSON police kit/welan police kit..) WOLO Noo York fire truck horns, RHINE tug boat horns... 18"truck horns..Oh..and the orriginal M54a2 horns!..Goes down well with ditherers...and at shows..specially with the "lights" a going..
