802a fuel pump ??
dogkiller
frisco/tx
found a bad fuel pump on my 802a
anone know a part # or suplier for it??
it's made by facet but has no # on it
24v of corse, 1/4" pipe fittings in & out and then to a/n fittings
it's the cube type pump, not the round one...
as always, thanks in advance for all the help..
d.
Stonepicker1
86
Coconut Creek, Florida
Some more info:
MOUNTING TYPE
NONSTANDARD
MOUNTING HOLE QUANTITY
ACTUATION METHOD
ELECTROMAGNETIC
FORDING FEATURE
NOT INCLUDED
MAXIMUM DISCHARGE FLOW RATE
0.05 GALLONS PER MINUTE
MOUNTING CONFIGURATION
2 HOLES 180.0 DEG APART
MOUNTING HOLE SPACING
2.480 IN.MIN 2.580 IN.MAX C TO C
GROUND POLARITY TYPE
NEGATIVE
VACUUM BOOSTER
NOT INCLUDED
FUEL FILTER
NOT INCLUDED
PRIMING LEVER
NOT INCLUDED
INLET CONNECTION TYPE/SIZE
FUEL 1/4-18 NPTF
OUTLET CONNECTION TYPE/SIZE
FUEL 1/4-18 NPTF
DRAIN FACILITY
NOT INCLUDED
CRITICALITY CODE JUSTIFICATION
FEAT
VOLTAGE IN VOLTS
24.0
SPECIAL FEATURES
WEAPON SYSTEM ESSENTIAL
TERMINAL TYPE AND QUANTITY
2 WIRE LEAD
dogkiller
frisco/tx
up & running
got the fuel pump in, it was a pain to bleed but worked great..
start bleeding at the filters then to the inj lines then to the inj pump lines at the inj (on the side of the engine)
you have to crank the engine to do this, the dead crank switch will crank the engine but shuts off the fuel.. so if your working by yourself unhook the fuel shutoff (unscrews from the actuator) & then you can use the dead crank switch to start,
just be sure to reconnect when it starts. it will start running as it bleeds...
once again thanks to all, & hope this helps in the future....
