803a Battery charge gauge ?
paine
23
SE Michigan
Happy 2018!!!
I have a 2007 803a that has new batteries and checked with a multimeter, appears to be charging. The gauge also shows discharging on prime\pre-heating, shows charging in initial start-up but shortly after start-up the gauge will show zero. Is this normal? Does the regulator stop charging the batteries when they are fully charged?
Thanks in advance.
kloppk
3,242
Pepperell, Massachusetts
All is normal.
It will show discharging when on prime or preheat since the engine isn't running and you're drawing current from the batteries then. Discharging.
Once you start it the batteries start to re-charge. Charging.
After a short time of running the batteries are fully charged and the meter drops back to almost zero.
Yes, the regulator tapers off the charge as the batteries approach 100% charge.
After that the alternator is just providing power to keep the set running. Fuel Shutoff Solenoid, Gauges, Panel Lights, Fuel Pump(s), relays, etc.
csheath
197
FL
Tip: If it continues to show a high rate of charge after a long period of running your batteries are probably failing.
I noticed mine never tapered off to zero during last months test and this month it was dead. The charge indicator stayed up around 10-15 amps. Thankfully my batteries were one day from the free replacement period so I got two free ones.
Guyfang
23,030
Burgkunstadt, Germany
Classic symptom. The alternator continues to high charge, long after it should have gone down. Always stop the set, disconnect the batteries, and measure the batter voltage. If the battery has less then 12 volts, start looking for new ones. You can also use a battery load tester.
paine
23
SE Michigan
Thanks guys.
I figured it was normal but just wanted to make sure. Good tip on how to know if your batteries are weak when it shows constant charge!
