Rellierell 803a
- 6
- 3
- Houston, Great State of Texas
Hello everyone,
I've followed lots of information found here and online. My 803 has 2 new IPs and two older ones. I took the advice and utilized heaters to provide a load. Initially 2 heaters would only give 10k watts max which the genset had no issues. I recently found a 7500 (6250 on low) model and added it to one of the original heaters.
Problem:
6250 + 4000= 10250 - no issue
Add 1k more and the genset throttles down and won't recover even when removing the load.
7500 + 3000= same, throttles down quickly
I've even tried increasing throttle before adding the 2ng heater, appears dies slower but still same result.
Injection pumps are set all the way counter clockwise (less fuel?).
Could that be my issue or is there another problem?
I've seen others test at 100 and even higher, I'm trying to do the same in preparation of a real need.
Thank you in advance
Problem:
