805a Low VAC & Hz on run, but perfect when held on start
kirkmarsh
Florida
Hey all-
I am very new to generators and forums. Please let me know if this issue has been discussed and I'll dig in here another couple of hours.
I have a new to me 805a and the engine seems to be running fine. When I start it, I hold the start for 10 seconds as described in other posts. When I do this the generator holds 60Hz and 120 volts just fine. When I release the start switch to run, the Hz spike to max, then decrease to 53 Hz and hold steady while the volts plummet to around 28 volts. Please let this be a quick fix and not a death knell. Any thoughts anyone?
Things I have done:
Confirmed it is set to 60 Hz on interior panel
Reset the Overspeed on interior panel
then
Reset the Fault Indicator
FNG
K
kirkmarsh
Florida
I don’t know. I just got the genset and I’m new to this. From the threads I looked up I need to find “a big honkin’ fuse.” I am looking now and it doesn’t seem to be modified. 88BF67A8-A126-4F42-A280-11D67F55648C.jpeg
kirkmarsh
Florida
I don’t know. I just got the genset and I’m new to this. From the threads I looked up I need to find “a big honkin’ fuse.” I am looking now and it doesn’t seem to be modified. View attachment 785226
TB 11-6115-741-24, page 33 of 136 in the pdf file. Here's this TB - https://www.steelsoldiers.com/threads/military-mep-generator-reset-information.169771/
I do not think you have the Quad Fuse installed.
Other TMs you will need...... https://www.steelsoldiers.com/threa...-work-on-the-mep-805a-30-kw-generator.169069/
Now that I read this, I do not have it installed. I’ll get this done over the next several days and see how it goes. Thank you.
kirkmarsh
Florida
Hi there. Did the quad mod. When I turned it on everything worked correctly. Hertz was at 60 and voltage was able to be dialed to whatever needed. Then I plugged in a 13 amp power saw to the convenience receptacle. Should have looked at the amperage because it’s only a 10amp receptacle. Now I’m having the same issue as before. Any ideas? I reset over speed and fault indicator again. Nothing changed when I restarted. Feel like an idiot right now because it was working there for a minute and then I pushed my luck.
Guyfang
23,052
Burgkunstadt, Germany
Are you sure you are holding the S1 in the start position long enough?
Guyfang
23,052
That should be good. As soon as the meters come up and stabilize, that's good. A tad longer will not hurt. If you start and stop it, say 10-15 times in a row, do you always get the over volt light?
kirkmarsh
Florida
It’s been under voltage every time I have started the generator except for the first time after doing the modification. The only thing I can think of is that I disconnected the batteries to do the mod. Do you think that reset something that fixed it?
Light in the Dark
5,511
MA
Check for any loose connections, and simultaneously... hit every switch, nut, bolt, terminal strip, and anything you can with contact cleaner. Lets make sure the set is getting the best information possible to run properly.
