- 1,966
- 435
- 68
- Culver City, CA
At idle my truck's exhaust stack would vibrate to the point were the metal stack bracket and cab bracket would grind together. This would, in turn, make an annoying high pitch squeaking. The stock spring set up was not offering enough stand off.
I removed the inadequate stock springs, bolts, nuts and washers. I replaced with a neoprene Vibration-Damping Sandwich Mount. It has a 1/2" threaded stud on each side. I obtained this part from McMaster-Carr, p/n 9213K62
The only modification is to remove the L-bracket from the exhaust clamp on the stack. The original exhaust clamp ensures the stack stays secure to J-pipe. I purchased a second 4" exhaust clamp and mounted the stack L-bracket to it moving the stack bracket from below the cab bracket to above it. The dampener was then installed between the two brackets using 1/2" nuts and flat washers.
The exhaust doesn't squeak anymore.
