CaptFlyboy
- 0
- 0
- WI
Hi.. Newbie + not too mechanical. I looked at the M1009 battery wiring diagram so I know my two batteries are wired in parallel but not sure if they are wired correctly since it's always a bear to start when it gets cold <20. I know this is pretty common for diesels but it just seems the battery is draining too fast. Even with the truck plugged in I get maybe two or three tries before I need to charge the battery.the isolated ground is what makes it 24V.. they should be wired in series if nothing has been changed. Kinda hard to tell whats going on with no pictures. if some hack has been in the wiring and f-ed it all up... good luck. might just want to put full coverage on it and burn it to the ground.
I only see one alternator so it makes me think it was modified at some time. I've read if you have two batteries system that the weaker battery will drain the stronger battery to the weaker battery level so this might be why I'm not getting much cranking time.
So from the pictures can you tell if this truck has been modified to start with a 12v starter?
If it was wired wrong would it even turn over a 24v starter since it is wired in parallel so only putting out 12v?
If it only needs 12v to start then could I just disconnect the second battery & use it to jump start the primary battery when I need it jumped?
I could put a trickle charge on the 2nd battery when it's not being driven to keep it topped off.
I have this one on order from amazon which will work with either 12 or 24V systems...
NOCO Genius G7200 12V/24V 7.2 Amp Smart Battery Charger and Maintainer
Thanks for your help!
CaptFlyboy
