85 CUCV m1009 engine shutoff?
Franchey
Utah
Hey guys so truck seems all good but sometimes while In idle you can kinda hear the engine kinda struggle and once you press the gas it shuts off like it has no fuel and all the lights come on, this happens sometimes while driving as well. Could it be a fuel pump/ air leak or injectors?
cucvrus
10,507
Jonestown Pennsylvania
I think it could be any of the above mentioned. Dumb question but have you checked the motor mounts. Is it possible that the pick up line on the fuel pump is pinched or cut on the right front frame rail. It happened to me on 2 CUCV's the first one was a Rausch Creek and I kept running out of fuel. It was after I had gone wheeling over really rough terrain and it started like a flick of a switch. I went home and thought the injection pump went out. I changed it and could not keep it running. it did not leak fuel only left it drop fuel. I found it and changed the motor mounts. The second time was on terminus and I diagnosed and fixed it the next day. But it may just be the injection pump going bad. Check for wet spots and se if it holds prime. Does it start and stay running when cold? Good Luck.
