Farnorth
- 3
- 8
- Melfort, SK
I’ve got a fuel pump on my 88 humvee that I suspect is weak (no 9 psi at bleeder). I am unable to get the pump with the third port on it for the vent line. At least at the moment, I’m here in Canada and some things are really hard to come by. From what I can see an 86 Chevy 6.2 L fuel pump would fit and provide the exact same pressure, a slightly higher flow rate, but does not have the third port for the vent on the top that goes to the air cleaner. I don’t plan on doing any water forwarding with this unit, will this pump work in a pinch? Thanks.
