Matt98tj
- 0
- 0
- Charlotte n.c.
Ok so this is my first MV. It is a 86 1008 with the 6.2 in it.I got it from this guy who had put a button in for the glow plugs. The starter went out on it and I went to autozone wher they told me it was a 12v starter ;( so after i found out that it's not I took the starter wire of the (24v block?) and put it on the front battery. Worked good then 10 or so days later the truck did'nt want to start when it was cold ? I took the glow plugs out and they looked ok? so I moved the wire for the glow plugs from one battery to the other that the starter wire was on. And ....... yea the starter was on fire ;( I got a 24v starter that i put on it but nothing.I did find a wire that was burnt in too on the bottom (24v block?) fixed it but the starter want work. Is there a fuse that is bad or more bad wires? I dont know what i am doing with thas truck
O and this is my first time on a thead so not sure how all this works. Thanks
