DDT
- 0
- 5
- Southern Cal
Just fininshed my second banks turbo install on a m1009. First had dual batteries with 1 alternator no problem. My m1009 has the dual Batteries and Dual alternators. I had to remove the passengerside grounds from the frame near the lower radiator hose. (heat + will rub)
I have a good ground off of the valve cover stud so can I ground the pass alt there? I tried it and hooked up the batteries and a little sizzle (2-3 sec). So the power is running to the driver side alt wire along the firewall it got warm, not burnt but warm. I printed the circuits from CUCV Electrical and will redo the grounds for the alternators. Any ideas?
