880 blackout switch
Milt51
Douglas WY
My 880 has no lights of any kind anywhere with the factory or blackout switch in any positon. The fuses seem to be good, any ideas before I dive into this mess?
Thanks, Milt
:lost:
NDT
7,434
Camp Wood/LC, TX
Make sure you put the 3 lever switch in service drive before using the push-pull switch. Next, check for 12 volts on pin F on the connector for the 3 lever switch. If good, check for voltage at the push-pull switch with the 3 lever switch in service drive. If none, you have a bad 3 lever switch. Otherwise, just check for cut wiring, burned bulbs, and bad grounds. Good luck.
Milt51
Douglas WY
Thanks, have power to F terminal, nothing to push-pull switch will pull 3 lever switch out of my spare truck and try it.
Thanks again, Milt
