WA 8D battery hold down brackets (pair)
US6x4
2,466
Wenatchee, WA
I will be making up a batch of these custom 10 gauge battery hold down brackets designed for 8D batteries in the plastic military battery box. The J-bolts must be reversed/oriented so that the shank of the J-bolt goes through the inboard set of holes. Four J-bolts are used per bracket with the hole spacing at 11 3/8" x 18". The flange IDs of the hold downs is 10.957" x 19.488" so check to see if that will fit your particular batteries.
Price per pair:
$95 for stainless
$90 for carbon steel
*(plus quoted shipping)
With the amount of corrosion found near batteries, I suggest the stainless option.
Please let me know if you're interested and I'll add your name to a pair of these stout hold downs!
