9.00x20.00 to 11.00x200
tklm539
Bolton Landing NY
Hello,
I am putting 4 g177 11.00x20.00 on my deuce. I need to remove 4 ND's of the original rims.
I was thinking of doing the labor myself, part to learn how and part to save money. Could anyone tell me if this is possible with little more than a sledge and prybar?
also, can I use the tube for the 9.00x20 in the 11.00x20 or are the tubes size specific? Are there any other parts in the rim that I will need to get?
Thanks very much
Tom
1,807
Tom, I had to purchase a bead breaker. I tried with the spud bar, running it over, high lift jack and other method wiith negative results. Perhaps your mileage will vary. There are some interesting threads on breaking down tires.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
It is not too hard to do. After I posted that thread, I made one of the slide hammers the other guys mentioned. It works pretty well and doesn't wear out. The wedges I use in that thread eventually flatten out and are useless. Make sure you pull the valve core before you break down the tire.
1,807
FWIW I am a hardcore cheapskate and I still pay someone else to do this....
I must be even more hardcore as I can't bring myself to pay for even this. Took years for me to find the "right" deal on ebay for the bead breaker. After doing 5 tires in the recent weeks, it's paid for itself. I have a few left to go but I figure at one a week, I'll be done before summer.
1,174
Buy new tubes for the 11.00-20 tire size. Also, there are different tubes for radials and bias tires.
rmgill
14
Decatur, Ga
I bought radial tubes as they're thicker and more durable (they have to deal with more flexing by the radial tires). I used a duck billed hammer and got pretty good results. A big tire spoon with rounded edges for leverage on the tire itself is useful as is a set of 3 pry-bars from Sears. Those are very good for working the ring out of the rim carefully.
When you have it apart, take the time to deburr the rim with a file and wire wheel any rust and those burr spots. Pay particular attention to the groove and if you feel very attentive to detail, go ahead and get the rims blasted and reprimed/painted. That'll protect them over the long haul better.
1,174
Did you see the recent thread by Gimpyrobb on changing tires/breaking beads? its a good one. Gimp, can you put a link up to it?
rosco
Delta Junction, Alaska
The duck billed hammer is standard equipment, when you have nothing else to work with. You just have to learn how to swing it properly. You can make shift a couple of other pry bars. Cleaning of the wheel & the inside of the tire is important. I don't like to leave it wet inside. Replacement of the tube & the flap is very important, so you don't get wrinkles in the tube. Get the valve stem, nicely centered, so its not cocked, by the wheel. If your working real hard doing this, your doing it wrong. Tip: after the air is let out, and your about to pull it apart, put a smooth metal valve cap on the tube valve stem, to protect the end & its threads.
The major tire manufactures have safety bulletins out, on proper procedures. You should look it up and follow it. You CAN, blow yourself up! Chain the tire/wheel, before airing it up.. If you do a couple, then have the opportunity to watch a good tire man, do one, you will learn something. He'll make it look like poetry in motion!
Lee in Alaska
gimpyrobb
27,785
749
Cincy Ohio
DH, BFR posted it in the third reply.
1,174
OOPS! my bad, I guess I needed more coffee! Thanks Gimp
I guess I was focused on this in that post!
And laughing because it fits me too!
Big Mike's Motor Pool
i did all my tires and rims with angle irons and an ax. the ones on my deuce were a bear to get apart. soaking them with pb blaster helped. alot. the 5 ton rims i broke down for my tires were easier coming apart. some tires on my deuce had been on the truck over ten years where as the 5 ton my new tires came from recently came out of service and prolly had newer tires on it. also i found that the ring side was alot harder to break the bead on than the rim side. this was like this on all my tires
