hawk-aggie
- 67
- 28
- College Station, Texas
We have two 900 series 5-ton trucks with the same issue. Front turn signals didn't work on both. neither did the parking/marker lights. Every other light works - headlights, tail lights, side markers, black outs. Fiddled with the dump truck some. Didn't really do anything and presto the turn signals started working, but the marker lights didn't. On our wrecker, I removed the combination light assemblies and bead blasted the rust off all the metal inside. Checked power to the light assembly connectors - blackout ok, turn signal ??, marker light was a no go. Checked continuity of the wires in the light assembly - all ok. Put everything back together. The blackouts work, and now so do the turn signals. The marker lights do not.
So, what's weird is that both trucks have the same issue - only the front marker lights don't work. When I checked for power to those sockets, the digital meter I was using looked like it measured mV rather than V.
Any one else have the same issue? How did you fix it?
