900 series winch questions
citizensoldier
19
Northern Michigan. Smelt City
I sold a 5 ton winch to some friends of mine and it will be mounted on a tug boat using hydrolics to run it. This winch was off a 900 series so it has the coupler and hyrolic motor flange.. 1 1/4 shaft size is what he said. So far a civi size motor has not been found.
Do any of you have the model #, any of the other specs for the motor? Make, HP,valve size, anything?
I have not worked on a 900 series truck so I dont own any of the manuals for them. Thanks
Monkeyboyarmy
195
Kingsville,Oh.
I found a few things about the hydraulic motor.NSN number is 4320-01-137-6293. One vendor is Eaton Fluid Power,phone number 952-949-1694. I have not found any specifics of it yet.I'll be needing the same motor for my 900 winch also.
TigerHawk
Small Town USA
I just picked up a winch off a 5 ton!
Does anyone know how I may convert this to a hydraulic drive source on a M35? I could make an educated guess...But I would like to get it right the first time!
Thank you!
