932a2 Intake Stack
524
Hamilton, NJ 08690
Can you please identify the (3) ports in the intake stack?
I'm re-routing the intake stack from the outside of the cab corner to behind the cab because I've hit several trees in narrow trails and would like to protect the cap.
I pulled the stack and air filter-to-stack pipe and noticed the center air line port is completely block with 'sludge'. Its almost like wet/oiled sawdust caked on the inside of the intake stack, filter is perfectly clean and so in the engine side.
I am obviously going to clean it prior to reinstalling but I'm curious what its for and why I haven't had issues. Unless its for the CTIS.
Photos:
5,218
They're vents from the air system. I've got my truck apart and should be able to figure out the ports pretty easily if you need them. I think one of them was a transmission vent line. (Likely where the oil is coming from)
524
Hamilton, NJ 08690
I disconnected all three in order to remove the intake pipe and none of them where 'wet'. Seems like the "gunk" was sucked in through the stack.
I know they are intake ports or vents but I was hoping someone had a diagram or something similar. I searched the TMs a bit and wasn't able to find them. I know the one is for the air compressor supply.
jdknech
Jeffersonville, Indiana
the larger hose is for sure a vent for the air brakes (mine got pluged up, and my brakes started having problems) but mine only has 2 tubes, so the 3rd one on yours is prolly for ctis.. (mine is a A1 without ctis)
acme66
9
Plains, Montana
I have seen fouling like that on our tractors if they are running in a dusty environment and yet still sucking water like from a light summer rain. You see it on a log landing where the dust can get thick. No moisture or mud and it dosen't form conditions have to be right. Sets up like little spikes angled downward. Sticks together well, has to be scraped or smacked off by whacking on the piping with a hammer. Might not be any oil involved at all, just mother nature. Not saying that is what this is but it sure looks the same.
-Ken
