Csm Davis
- 382
- 83
- Hattiesburg, Mississippi
Just noticed a oil leak around the CTIS fitting on my rear axle today. My ctis is not functioning so air pressure isn't pushing it out. Any ideas on what to look for?
Yet another reason I don't like CTIS, now I will have to tear into a hub.Probably the outer outside ctis hub seal. That's what mine was doing. It seals the gear oil out of the center section of the hub since the a2 outer bearing is a wet bearing and gets its lube from the diff.
