A couple of M1009 questions --
Buckeye2000
Centerburg, Ohio
I've been through several threads for info and wondered if anyone has an opinion/advice to share - the speedometer is out on my M1009, and I figure it pretty much has to be either the cable or the plastic gear. I just got it yesterday so I don't know how it was acting before it quit (I'm checking with the seller). Would it make sense to check one before the other? Neither seems like a really tough job.
I also saw in the CUCV specs a couple of links for fuel-fired block heaters. Anyone have a particular block heater they would recommend? I have outdoor power and am open to a plug in heater as well - just wondered what some of you other cold weather folks use.
Ken_86gt
Williamsburg VA
Does the odometer move either? I would check the plastic gear first, it seems easier to me. If you have a helper spin the gear end you should see the speedometer bounce a little.
If you have electric available, I would go for that as it would cost less than paying for the fuel and also the cost of the heater. I doubt that you "need" one though. I remember many times starting these things when it was 0 degrees out and they still started. Just need a good battery when it is cold.
Buckeye2000
Centerburg, Ohio
Thanks for the input. I'll give the gear a try tomorrow evening. The odo is out as well, so you're probably right.
I'll see how the winter goes before I add a block heater. I just wondered what others were running. I've had a couple of other civilian 6.2s and they usually did fine.
kipman
15
Lancaster Ohio
Got my block heater at Oreilleys in Lancaster, the package is not near me, but they had three sizes and it took the larger size. I think I paid 26.00. If you get in a jam pm me, I am sort of close.
