I finally got my "PAID" invoice and drove down to look over my 2 M-35s to pull PMCS on them. Batterys on both were dead. I had already pulled the batterys on one before the Motor Pool Sargent came by and offered a jump. So with the jump it cranked right up.
Question 1: Is it okay to run them without a battery in it? My concern is that I had intrument indications for sometime as I was checking how the temp and pressures were. Then after about 20 minutes no more indications. Did the altanator drop off-line or did I mess something up?? The conectors did not ground out.
Question 2: When I shut the engine off a puff of white smoke came out of the hood. It came from oil that was spit out of a copper tube running up from the right side of the engine along the firewall and is bent 180 degress back downwards. I was pushing on the brack pedal as I shut it off. What would cause it to spit this oil out?
Thanks up from for any help.
Kevin
Kevin
