A little help with engine troubleshooting
Chinookpilot77
Enterprise, AL
My deuce is nearing completion and I'm getting ready to get her on the road. I do have an issue though.
She starts right up, first time every time, and idles around 800 rpm with throttle in all the way...purrs like a kitten, only 6k miles on the truck.
The issue is when I start driving it, I have to pull the throttle out to idle closer to 1200rpm so it doesn't die each time I let off the gas to shift or stop.
Once she comes back from the body shop I have to install the new filters and adapters, but if that doesn't fix it, I'll be at a stand still.
Any thoughts?
cranetruck
75
Meadows of Dan, Virginia
Besides the filters (the three of them), check the fuel lines, an air leak is possible.
Make sure the fuel cut-off lever/mechanism on the IP is working smoothly and not sticking. As a routine check, drain some fuel from the tank and check for dirt, debris, water etc.
Chinookpilot77
Enterprise, AL
I was leaning in that direction too, but I wanted to rule out anything adjustable/mechanical. I'll change out all the filters and maybe just drain my tank for good measure...hopefully that clears it up or I'll be bumping this thread! lol
Thanks bud.
