A/M32K tires
BigBand
N Idaho
Well, heck - breaking the ice here, and right away looking for some help.
I've purchased a trailer on Craigslist, and it appears to be an A?M32K-4A. Seller says the
labels on the side are unreadable.
I will need to tow it about 250 miles to get it home. Seller says the tires are 7.50x16,
and they are showing some weather checking. Two-piece wheels, 5 lug. He has used it
on the highway to go get hay, and says it tows great, but I'm sorta the cautious kind.
I'm wanting to have a spare with me 'just in case'.
Will a common truck wheel fit the lug pattern on these trailers? It would be great if a
5-lug Ford wheel would fit, or maybe a Chevy or Dodge.
I don't go get it until next Saturday, so I would have some time to get something if needed.
Thanks!
FloridaAKM
392
Gainesville, Florida
I recovered one that only had a 70 mile drive & did it with a Deuce easily. The trailer does have air over hydraulic brakes, so unless you have those connections, you will have no service brakes. The picture you provided doesn't look like the trailer I have, but they have a few similarities. Good luck finding a spare tire with rim that fits & be safe. Welcome aboard.
Matt0729
Il
It does not look like the m32k 4a. The deck looks different and there should be a lot more suspension under it. I don't think I would tow it that distance on highway. I would put it on a different trailer. It looks like a trailer for missiles on the flight line.
juanprado
2,898
Metairie/La (N'awlins)
The other pictures confirms to me that is a low speed flight line trailer by the tongue design and the rims and not an on road use trailer. Thanks for sharing.
