- 2,960
- 30
- 48
- Tiro, Ohio
Had plan A for replacing the down boom hose on the M108. Ended up with plan B
Plan A was to cut the old, hard to find, fitting from the steel line. Install a new compression fitting with a swivel end on it, then use a standard hydraulic hose. Then I found out the steel line was 1 1/8 O.D. and the fitting was 1 inch O.D.
Give a hillbilly a welder and watch the fun! Plan B, I welded the compression fitting to the steel line. Amazingly, it doesn't leak.
I will look and see if Parker makes a fitting for 1 1/8 steel line. If so, it would be pretty easy to change the hard to find fittings.
Someone made up adapters for the rest of the old fittings. Not sure if they are homemade, or were available at one time. The adapters have been on there for a long time.
Some part#'s.. the hose fittings are Weatherhead brand, the compression fitting was a Parker brand. Don't have a part # for the parker fitting.
1 inch hose to 1 inch pipe 16u-116
1 inch hose to 45 degree swivel 16u-696
1 inch hose to straight swivel 16u-692(this number was from memory, may be wrong)
