A0 Alternator excite wire question- Get Well grounded
coachgeo
3,392
North of Cincy OH
now that it is warm... my alternator occasional works LOL. (200 amp Hummer)
Will the excite wire get voltage if the alternator ground is not at all or is poorly connected? Knowing that will help me diagnose if it is that or ground (or regulator)
Ronmar
6,829
Port angeles wa
The excite wire is fed down from K11 once the oil pressure goes above 15 PSI and de-energizes K11.
now that 24v’s ability to do anything in the regulator once it arrives at the excite terminal relies on it being able to complete a circuit to ground…
GeneralDisorder
4,409
Portland, OR
Don't neglect the cab ground under the grill. That one is a TERRIBLE design on both ends. Cab side is laughably poorly designed - on my truck the weld for the stud is so proud of the surface that the star washer they "installed" under the cable just hovers in mid air about 1/8" off the cab surface instead of piercing the paint and making a solid connection. The frame side is horrifically inaccessible - requires a 17mm open end wrench and a lot of swearing. I relocated both ends of the strap.
coachgeo
3,392
North of Cincy OH
where is that one?
Redid the alt ground a bit (could not get bolt off.. but spun the shiat out of it with the impact to help it clean itself) and cleaned the ground by the starter. Added a ground from Batt to the chasses.
Ronmar
6,829
Port angeles wa
where is that one?
It’s behind the grill, runs between passenger frame rail and a welded stud up in the engine tunnel.
GeneralDisorder
4,409
Portland, OR
It's behind the grill - on the passenger side of the radiator tunnel. Other end is under the cab mount rubber stop on the frame and isn't even accessible for a picture. Have to disconnect the CTIS air lines, cut a bunch of zip ties to move wiring and AC hoses then throw tools and swear at if for an hour or so.
This is the upper mount stud. Completely worthless. Inaccessible to "fix" it so the strap can sit flush and have the star washer pierce the paint.
You can see how the strap and the star washer are proud of the surface due to the weld not being ground flat around the stud. It was only making contact through the deformed-thread lock nut and the flat washer on the front side of the strap.
I reversed which end was on the cab - the frame side has a larger horseshoe opening and worked perfect (with the star washer in place) on the cab hinge bracket. I drilled a new hole for the frame side on the frame nose behind the bumper. I didn't have to modify the strap (which is in great shape on my truck being from the desert).
(I used the other end for this connection - didn't want to enlarge the hole for this socket-head mounting bolt).
GeneralDisorder
4,409
Portland, OR
I've seen a huge voltage drop on that cab ground strap on a 3 year old A1P2 - the voltage drop was causing all the lighting and dash gauges to go out, the ABS had a code stored for retarder relay control. Oshkosh didn't remove the paint on the cab stud and the star washer didn't pierce it effectively and the whole thing was painted over with a poor connection. Since all the lighting and most of the vehicle electronics are grounded to the cab itself none of it worked properly.
MatthewWBailey
Father, Husband and Barn Hermit
968
Mesa, Colorado
You can see how the strap and the star washer are proud of the surface due to the weld not being ground flat around the stud. It was only making contact through the deformed thread lock nut and the flat washer on the front side of the strap.
That looks easier to get to! I looked in there on mine after you alerted me to the inaccessibility. I'll just add a braided ground like yours. No need to increase the amount of swearing I'm doing
GeneralDisorder
4,409
Portland, OR
Yeah - since I ended up moving both ends it would have been just as easy to get a new strap and forget about the old one. But now we know!
Ronmar
6,829
Port angeles wa
There is another one up under the power panel between the ground test point in the power panel and the extreme right end of the dash assembly(over by the door hinge on my A0).
GeneralDisorder
4,409
Portland, OR
Yes - it's on the grab handle mounting bolt on the passenger side of the dash right? That one relies on the one under the grill to get back to the frame and ultimately the battery negative.
Ronmar
6,829
Port angeles wa
Yes, exactly. The ground terminal board in the power panel, TB2 which all the circuitry is grounded back to, is tied to the ground test point. Its tied out to the panel edge and the grab handle bolt. Then Thru the dash and cab chassis to the ground lead behind the passenger grill down to the frame. Thru the frame to the starter ground strap, and thru the main ground lead back to battery -…
