- 44
- 8
- 8
I think I have found my answer to eliminating the “military only” and rare parts in the electrical system. I will replace the Niehoff alternator with a $500 CAT brushless 24vdc unit and a CAT alternator bracket. I will wire all batteries for 24vdc operation. I will install a 24-12 converter and feed the 12vdc loads directly at the main cut off switch. That way the 12 volt side will see no change and neither will the 24vdc side. I can eliminate the LBCD completely and only will loose the function of the “No Charge” light on the dash as the LBCD controls this light. I will still have operational gauges for my 12 and 24 voltages . A 100 amp converter will be plenty for the 12 volt side as I only get around a 32 amp draw with everything operational on the 12 volt side. If I still want to know when the alternator stops outputting I am sure I could install some sort of ammeter later to monitor that. With this method I can go anywhere I want and any of the parts I need for the alternator or charging system will never be more than 2 days away. Everything would be available on the open civilian market including Amazon. I could still retain the LBCD to provide reverse polarity protection for the 24 volt side if I wanted. The converter has that protection built into it for the 12 volt side. What does the group think?
