A3 bed on A2
shenkmen
12
Lancaster, PA
Hi there,
I'm replacing the semi rotted bed on my A2 with a bed from an A3
The A3 bed has a bracket which the rear marker lights and trailer plug mount to (see attached pic).
Questions...
  1. Will my stock A2 wiring harness allow the trailer plug to mount in the A3 plate?
  2. Can this plate be removed and installed with the bed on the truck?
  3. Where can I get one of these brackets? Lights included would be nice. I've been calling around and haven't had much luck.
  4. Any other tips on this swap? I know I need to remove the mud flaps and pioneer rack and plan on soaking all nuts with PB Blaster ahead of time. All lights have been removed from the A3 bed.
Jake0147
Panton, VT
Wait, I thought the stock A2 beds were reused? Is that an add on (cut out and add on) or were new replacements spec'ed that way at some point?
shenkmen
12
Lancaster, PA
If the beds were reused they were modified. All of the A3's that I've seen have that light and trailer plug setup.
Any help out there for my original post?
1,128
Yes. But you will have to add some wiring in order to run the additional lights an A3 bed has. My A3 bed has a small wiring harness that plugs into the standard rear harness.
I think so. Goes out through the bottom.
I'll bet you will have a very hard time sourcing it. You probably will have better luck fabricating it. Try Memphis, Clark, White Owl, etc. Start at Memphis.
Don't forget the wiring. Replace and adjust the parking brake while the bed is off. Paint frame and axles if desired while bed is off. Bed weighs approximately 1500 lbs, so don't drop it on you. Have new wood strips ready for swap. YOu can lift the bed by the cargo tie down hooks. If you plan on repainting the truck, go ahead and paint the back of the cab while you have access.
