A3 fan hub switch
MATT
Colorado
I am looking for a A3 fan hub switch. It's the switching device that turns the cooling fan on when the engine reaches 200 degrees. It screws into the thermostat housing and has 2 air lines attached to it. I looked in the tech manuals for a NSN with no luck.
thanks
glcaines
2,548
Hiawassee, Georgia
This unit is called the shutterstat air valve. I don't know the P/N. It is possible that this could be obtained from Caterpillar. If you contact a Cat dealer, make sure you have the S/N of your engine. There are many variations of the 3116 engine.
R Racing
St. Leonard, MD
I had a bad Shutterstat on my m920 . My fan was always on even from a cold start at 19 degrees lol If you can't find it from cat and you know if its a normally open or normally closed and what pipe size I can give you a sorce for them.
